RCU Forums - View Single Post - High wind technique
Old 03-14-2011 | 03:36 PM
CGRetired's Avatar
CGRetired
Default RE: High wind technique
ORIGINAL: harryangus
All those landing techniques including crabing that I read about make sense if you have 5 minutes on final on a real plane.
I find it difficult to see how an RC flyer can do all that in the 15 seconds we have on final.
This is NOT for a beginner.
I'd rather pack and go home on a strong wing or crosswind. At least for the moment.
And, if you don't think RC flight doesn't look like the video presented in this thread, well, guess what... it does. And it didn't take two minutes, either. Although it was an extreme example, it IS an example of a crabbing approach and final. It is simple to set up, but takes a moment of thought on the downwind prior to the turn to base, that you make the adjustments necessary to actually make the turns, then apply and hold the right amount of rudder to make a safe landing.
This is not something that you 'just get', it's something you practice and learn to do. Nothing in this hobby is done by osmosis, it is a learned process done over and over again. And, guess what, it's both challenging AND rewarding... as well as fun!!
You can go home, or you can stick around and learn something.
Granted, there are times when we have all just gone home. It takes some experience to learn your limitations, then either stick with them, or learn to overcome them. Either way, it is, as I said, both challenging AND rewarding. There is no wrong answer. If you want a challenge, then stick around. If you just want to fly and avoid problems, then, do as you wish. As I said, there are no wrong answers here. A lot of us prefer the challenge, though.
CGr.
