RE: KingTech K-80
I believe the only way to effectively increase the thrust of any given turbine without actually opening the can would be to increase total rpm, would it not?
So bye bye warranty.
However the max rpm is locked in the ecu. so suppose that if the factory was doing this for someone then the turbine would still be warranteed?
The only reason ask this isbecause saw in the classifieds a pair of factory boosted k80's.
