TJ Failsafe Question
Hi,
I've installed one of these units for a customer and have an issue. When the Rx batteries are turned off and then back on, nothing bad happens, but when you cycle the Tx also, the gear are commanded to retract upon power-on. I've binded it both ways, but it does the same thing either way. I'm sure there's a solution or something I'm not doing correctly. Thanks in advance for the help...
