RE: Futaba 12Z programming question.
Set up the nose wheel so that one of the dials is the control for that channel.
Now mix the rudder to nose and select athe same switch as you had used for gear up/down to turn it off/on
This will make the nose adjustable (trim) with the dial and will turn off the mix from the rudder when it is retracted.
