RCU Forums - View Single Post - I give up! Engine problems
Old 08-10-2003 | 03:33 AM
georgehere
Default I give up! Engine problems
The final test you can make before taxiing out is to go to full throttle and hold the nose up. It should continue to run and not lose any rpm. If it quits, it's too lean. Best if you work the throttle and have your friend hold the nose up. This simulates the nose up plane in flight and checks to see if it will stall. Just my $.02.
