RE: Micro t-28 trojan?
I have the plane and it is a great little flyer. It will handle a little wind, but could be a hand full on the landings. It is pretty responsive for a micro, but don't plan on too many aerobatic moves. You can do loops, roles, and the such. Takes off quick and lands in a short distance. I will tell you to get a couple of 3.7 volt 160 mah batteries though. The 160's will give you longer flight times. If you just stick with the battery that comes with it; you will fly about 10 minutes (depending on throttle control).
