RE: new to nitro
Sounds to me like the screw(bolt) that secures the throttle arm to the throttle barrel is not tight.
I havent owned many OS engines...but some of them I have owned have a plastic arm that just bolts to the barrel. If the screw that secures this gets loose, you have no control over the position of the actual throttle. The arm will move...but the barrel will not.
