RCU Forums - View Single Post - Jump angle for ultimate jump?
Old 03-17-2011 | 01:11 PM
djyjrlz's Avatar
djyjrlz
Default RE: Jump angle for ultimate jump?
to be honest the only goal of hat video was to get the MOST air he possibly could, <div>it wasn't exactly controlled, it has rockets so it isn't a controlled jump. basically just sent it spinning end over end about 20 times.</div><div>
</div><div>IF you were to run a monster truck 'aka well set up savage' you would get some good results on landing if you jumped it properly. </div><div>working with a lot of dirtbike jumps it happens to be that a jump with a take off of around 30 degrees will get you the right height/distance ratio but the size of the ramp depends on the size of the building. just guess at size and do some testing for distance and height and then add the building as well as a nice big landing ramp on the other side and you should be dandy. </div>
