RCU Forums - View Single Post - Nitro Planes Starfire EDF
Old 03-17-2011 | 03:00 PM
Greg Covey's Avatar
Greg Covey
Default RE: Nitro Planes Starfire EDF
I replaced the stock fiberglass roll with my own Mylar for the thrust tube as it was a little short for where I mounted my Lander DF. I may use the fiberglass roll to smooth out the air intake area when I clean up the intake ducting.
My normal FSA was used from other projects as it is a good compromise between thrust and speed. The tube length of 12-1/2" was used to allow it to exit the tail. After taping the thrust tube to the DF, I sealed the opening for the motor wires with some Plumber's GOOP.
I added some black paint to the rear former to enhance the look.
The bottom hatch was held in place with some clear 3M Scotchcal strips.
ID:	1580129   Click image for larger version
ID:	1580130   Click image for larger version
ID:	1580131   Click image for larger version
ID:	1580132   Click image for larger version
