RCU Forums - View Single Post - High wind technique
Old 03-17-2011 | 05:10 PM
  #84
cfircav8r's Avatar
cfircav8r
Default RE: High wind technique
For a steady wind you can do a forward slip to landing all the way to touch down. This is a standard technique taught at many flight schools. You touch down with the windward wing low and that wheel will touch down first. You use the rudder to keep the nose pointed down the runway and use ailerons to stay over the centerline. If done properly you will have a slight bank into the wind and the nose will be pointed straight down the runway. It is a very stable maneuver and requires no timing like the last minute rudder kick. Only a slightly higher airspeed is recommended. Now this can be a lot harder with a model then it is with a full scale, which is why I didn't bring it up before. The point I was trying to make though, is the wind will not get under the wing while in the air and flip the plane, so don't be afraid to use a little aileron as long as you have enough speed.
