ORIGINAL: bcrc
I have a Moki 150 and I worked this out. Of course you would have to move the firewall back and restructure the motor area, but then it would fit just fine. Obviously the firewall for the Moki 150 cannot be in the same place as where it would be for a typical single cylinder 2-cycle gas engine.
Good thought on the fit. Would you move the firewall back to inset the mount and allow the carb to rest inside of the fuse behind the firewall?
If so, does this allow the Powerplant to set inside of the diameter of the firewall as the full scale Stearman rested inside of the bowl?
Can you provide some drawings or dimensions? I would still like to fly a MOKI while I construct my Kellogg AD-5 and Z-Hellcat. I just did not want to buy and let my engine sit. This was recommended against in this thread. Something about allowing the warranty run out.
This would be one nice plane with a round engine.
