Monokote Help
Could you be using too much heat? Over a solid surface, you just want the Monokote to adhere, not shrink. The Monokote adhesive is activated at a lower temperature than is needed for shrinking. So, you may be causing the Monkote to shrink before it is stuck to the wood - causing the wrinkles.
