RE: Flame out
Low rpm seems to be the most common flame out condition, due to heaven knows what, to try and ovid this issue I have programmed in an idle up with gear retract, so low rpm is about 15,000 higher than normal idle, this only works in flight mode with the gear up, obvious what happens when you lower the gear to land.
Mike
