RCU Forums - View Single Post - nitro planes, no response
Old 03-21-2011 | 08:43 PM
azmld
Default RE: nitro planes, no response
I will past and copy what I posted to RCDISCUSS
Thanks , I think???
Went to LHS and purchased new , brushless , prop , and was talking to vender about problems.He said he usually wont do this, on a plane he did not sell,bring it in and he would have a look. He also said that the 2-4degrees are common , but he said I was new and ,it still will not be that hard of a right turn.He said that I did somthing wrong.He helped me install needed parts and we buttoned it up.He moved the position on the control horns , on ailerons , to get max throw. We went out to the parking lot and HE tried it , it took a hard right , except he did not let it get only a few inches off the ground , and landed it .
Now even he was at a loss . We went inside and he put 2 washers behind the motor mount( it was still at an angle) took it outside , up it went straight  as could be ,he still said i needed to use more left turn than there should be.
Went back inside and purchased a new plane from him.
Went home and took new plane(after setting up) poped it in the air and few it untill batts were getting low,no problems.
Got out PA 18 (after charge) and it came up but hae to keep tapping left , to keep it somewhat straight.
Got out both of my corsairs (from Nitro)up they went no prob)
