RCU Forums - View Single Post - 12z programming
Old 03-22-2011 | 11:56 PM
DrV's Avatar
DrV
Default RE: 12z programming
ORIGINAL: Bax
You need to use a condition. Set the condition to turn on when the gear is in the up position. Turn on the condition. Go into the Model Menu and then the AFR section. Go to the nosegear steering channel. Set it to ''Single''. Adjust Rate A and Rate B to 0%. This will give you a flat, horizontal line. Now, when you raise the gear, the nosewheel will center and remain there no matter how you move the rudder. When you lower the gear, the original endpoint setting will take over.
Thanks Bax but for some reason it did not work. I have a rudder to Aux2(nose gear) mix. Aux 2 is ch 10 and I have assigned control on LD with no (null) trim. Do I need to create a second condition? Because in condition 1 when I go to AFR menu for Aux 2 and when I move the rudder stick on the radio I don't see the graph moving. It will only move if I turn LD thus Adjusting Rate A and B does not do anything but to stop the entire Rudder to Aux2(nose gear) mix.
Sorry still trying to figure out this radio.
