RCU Forums - View Single Post - Engine Problem
Old 03-23-2011 | 04:20 PM
safeTwire
Default RE: Engine Problem
IMO, it's a vibration issue which does not show at first, due to a full tank. After some time, the fuel level lowers to a point at which the still present vibration causes excess leaning of the mixture, which leads to power loss/engine quit.
For starters, try a different prop, and if you are running a spinner, make sure it is in good shape and spinning true.
Good Luck!
PS: I have seen a tank foam up, like a Maytag clothes washer, due to bad engine bearings!
