RE: Brison engine ignition problems.
You will need one of the earlier models that does not have the timing retard and advance.
You might get one by putting a add in the wanted section in the for sell forums here on RCU or check with Ralph and see if he has one.
You can use a RCexl ignition but you will have to set and lock the timing on your engine to 28-30 deg before top dead center.
Mitlon
