RE: Can I Produce Washout with Ailerons
I don't think this has been mentioned yet, but an easy to do, and try, fix is a stall strip. A small triangle stock strip, about 1/8th to 1/4 span tacked to the leading edge inboard part of the wing will cause the inboard portion to stall first and not change the cruise flight noticably.
