RE: two choices...
Yes it is. The biggest repairs that will likely happen are dog bones and wing or wing mounts. I have been lucky with aluminum bulk heads in all major crashes just being able to bend back but all good things will come to an end soon few more and I'm sure the bulk heads will need replaced. I will down load track pics later from today! You just need to becareful on starts because the pull starter can cross the throttle link if pulled at akward angles. Easy to tune and with Redcats support videos you can learn all you need to get going...
