RCU Forums - View Single Post - Rx battery check
Thread
Rx battery check
03-26-2011 | 06:07 PM
12
Phoenixangel
Jan 2009
611
Locust Grove, OK
RE: Rx battery check
Quote:
ORIGINAL: lopflyers
Quote:
ORIGINAL: Phoenixangel
These will check the battery under a load similar to that of servos in use, and give you a good idea of your battery power.
http://www3.towerhobbies.com/cgi-bin...?&I=LXWDZ5&P=7
It is a must for any field box.
Another nifty device that is often recommended and they do work well is
http://www3.towerhobbies.com/cgi-bin...&I=LXHDJ2&P=ML
The voltwatch is optional but for sure invest in the expanded scale voltmeter. These devices will save planes.
This Expanded scale voltmeter is rated only for 4.8v batteries, does anybody knows if they also come for 6v 1600mAh 5 cells?
It does them all you just change the positive lead to the right side for higher voltage
Reply
Like
Phoenixangel
View Public Profile
Send a private message to Phoenixangel
Find More Posts by Phoenixangel
View iTrader Profile
