ORIGINAL: hazardousoutlaws
new at this can someone help me. build a airboat. battery got charge the servo will not work. they make a little noise first plug them in that all. they sitting about 1 1/2 apart</p>
Did you connect the battery and servo connectors to the receiver properly? If they're backwards the servo won't work. Also make sure the receiver and servo connections are free of corrosion (that is if this is used equipment).
Are both servos not working or just one of them? (I'm assuming its a 2-channel radio)
