RCU Forums - View Single Post - Elec problems
Old 03-27-2011 | 11:42 AM
YHR's Avatar
YHR
Default RE: Elec problems
ORIGINAL: 1sgt
Well, no use. I reversed the motor leads and my forward/ reverse stick became left and right turn. and my turn sticks became forward and reverse?? go figure. I guess for the time being, I'll just have to get used to driving this tank in reverse fashion?
Jim
Hey Jim there has to be an answer for this. I have changed gears and motors at least 50 times, and have experienced what you have relayed. It was always corrected by rewiring the motors or moving th eplugs around. Through trial and error you will get it. There is only so many combinations!!! When you move the right stick, upper left, the right hand motor should turn in a forward direction. So if this upper left action causes the left motor to turn, you need to switch the plug in on the RX 18. If the motor is running in reverse then you have to swap the leads on the motor.
