RE: CrazyBall
I have found the problem that crashed me yesterday. I did not have full vane rudder I had full right but not full left as the servo arm escaped the glue All fixed now
And now for something far more important. I have made the Crazyball mix adjustments. To start with, I had already mixed rudder and flap(ch 6) as an always on, to match up with the Delta, or Elevon mix.
Next, I mixed the ailerons to both the rudder servo and the flap servo. On my radio, DX7, this was a 2 part deal ail-rudder and ail-flap. Aile-flap is -100% for both rates. Aile-rudder is +100% for both rates. I put these mixes both on Flap 2 switch. That way I will never hit the wrong switch. If you have a "Heli" radio(that heli image saved me some $$), as mine is the Switch is identified as flap in the programming but marked flight mode
I hope that is helpful.
Tim
I will see about putting the 2 lost CrazyBall videos up in a little while. One of the vids has a 10" prop installed, the other is a TGS 9X47 prop.
