RCU Forums - View Single Post - Balsa USA Super Cub Build
Old 03-27-2011 | 01:16 PM
  #470
fred985
Default RE: Balsa USA Super Cub Build
i hope you guys using the randthane/imron paints know that this stuff is deadly if you dont use the PROPER breathing gear. the pros use full masks with pumped in air.,,,years ago a friend painted his pick-up in his 2 car garage. he shot it with imron and died from empasema,,,forgive the spelling,,,,the medical exsam after he died was that it was the imron.,,,,,why paint a cub with this stuff,,,?,,,use buterate dope and it looks just like it is supposed to look.,,,,plus it is easy to repair.,,,,i use the stits on all my planes. jusd give the leading edge etc a double coat of clear and let it dry....use a third wet coat and get the stits on it,,,,gise anopther coat or two and get the top covered the same way.,,,yhre coverring will never come of.....the silver coats are to protect the covering from the sun.
