There you are
Great add with the radial and especially the oleo struts, now when you say wire can be added for wing and landing gear support, does that mean the mounting supports are already in the wing and fuse or does that mean we as modelers will be responsible for going into the structure and adding our own attachment points? The wire also attaches to the gear through the wheel pants, that would be another concern. While I'm bashing,[:@] is there a possibility that the fuselage could get a little more sheeting. From the pics it appears that the wings are fully sheeted, which is very nice, and the fuse is only partially sheeted. A fully sheeted fuse would look 100% better and add a lot of structural support. Thanks for listening Gerry and hope to be contacting you soon for a little jet fly
will be in touch
Go low if you wanna make a show
Jimmy
