RE: Gruman Ag-Cat
Hi everone I order one of Duane Agcat 104in I will install a moki 150 on it.I run a moki 215 on my pitts M12 that is about the same size as the agcat the plane is about 42lbs I was runnining the 150 on it but needed a little more power so I install the 215.The 150 will fly the agcat just fine should come out to about 35 to 40 lbs, Duane called and said plane should be ready in about 2 weeks .
Thanks for post wr450
