RE: Welcome to Club SAITO !
The difference is in the validity of the numbers you are reading
I would venture to say that the "B" engines are both heavier then the "A" engines because of . . . .
The aluminum back plate rather than the plastic one
The longer steel cam pivot shaft
And the increased weight of the crankcase casting and cam cover
The rest of the parts are the same
