multiplex mentor
I have a question about the servo power supply
the mentor comes with a 55 amp speed control and it has a built in 3 amp bec
do you think the 3 amp bec is enough to power the 4 servos
the ale servos are hs 82 small servos and rud and ele are 322 mg standard servos
their all analog servos do you think the 3 amp bec will be enough or should i run a second battery
thanks all..
the lipo battery is a 2200
