RCU Forums - View Single Post - multiplex mentor
Old 03-29-2011 | 10:59 AM
Glacier Girl's Avatar
Glacier Girl
Default RE: multiplex mentor
You should be fine. But another great use for a watt meter. Make up a pair of adapter harnesses so you can install the meter between the esc's servo lead and your rx.
Power up the esc and work all your servos at the same time. You'll see if the voltage sags from the bec, and how much your servos are drawing.
And good on you for asking first.
