RE: Correcting adverse yaw
Actually, the only way to correct 'adverse yaw' is to use rudder. All the other fixes mentioned will reduce the effect, but at the expense of some reduction of control authority. Mixing a bit of rudder/aileron in your computer tranny then playing with the amount until you have a nice balanced turn will be all that is required.
Evan, WB #12.
