Phoenix With JR 9303
I have the Phoenix simulator and I am using my JR 9303 with it. I read while setting it up that you should use heli mode on the transmitter regardless of what type models you fly on the sim. However, I am having a problem setting up my flap switch in heli mode to work the flaps on the airplanes. It's as if there is no output from the switch which leads me to believe it is a setting on the transmitter. So I guess my question is what switch does the flap switch become in heli mode and what setting do I need to change in the transmitter to activate the flaps?
Brian
