RCU Forums - View Single Post - Correcting adverse yaw
Old 03-29-2011 | 06:20 PM
tomfiorentino
Default RE: Correcting adverse yaw
I understand that both are correct; ailerons cause yaw and so does the tilting lift components due to roll.
The down aileron increases camber, increases lift and increases drag. The opposite is true; up aileron decreases camber, decreases lift and decreases drag. The delta in the drag causesthe yawing moment.
I don't know which one accounts for a greater percentage of yaw...ailerons or lift tilt...but I imagine there are other combinations and dependent variables.
Tom
