ORIGINAL: tele1974
So, Norlocks with blue locktite and aluminum can gasket. Did you guys uses a sealant also along with the gasket?
I have never used blue loctite on exhaust bolts threads. I think a couple guys did that before we found out about how well Nordlocks work, and their bolts stayed put. Getting the bolts loose is another matter that requires heat, as I understand it
I use Nordlocks, ally can gasket and Locktite Ultra Copper silicone sealant on both sides of the gasket and inside the bolts holes. This combo has solved the loose exhaust bolt problem we experienced early on.
Planning to go to Toledo this weekend with Ed. Hopefully I'll get to chat with Todd regarding some of the ideas I've presented here-in
