RE: C-ARF Ultra Flash build Thread + Video
Hello everyone,
In the manual its mentioned that I need to get the inner thrust tube to at least 8 mm to the outer thrust tube. To acheive that I need to insert the pipe into the bell mouth only 5 mm which is too little. At the end, My setup ended up with 15 mm to the outer thrust tube. I didn't think it would make any difference, what do you think?
Hassan
