RCU Forums - View Single Post - Piston Stop Using A Spark Plug
Old 03-30-2011 | 10:55 AM
captinjohn
Default RE: Piston Stop Using A Spark Plug
ORIGINAL: av8tor1977
Hi,
I have seen piston stops for sale, but I can't remember where. I just gutted a spark plug, and used JB Weld to install a piece of aluminum tubing for the stop. You could use a dowel, but the tubing allows the air to escape and lets the engine turn over easily when doing timing chores.
AV8TOR
I like the wood dowel better. Sand it round on end... not to damage piston. Drill a small dia hole through it to prevent compression. Easy made. Capt,n
