Jucava I order 6 of them today as well as another set of the wooden ones
Borzack we used one behind a JD 6410. It was called a Duvall. We are getting rain right this second. In a couple of days when it begins to dry we will then roll it again. it should pack tight. After that we will get the 36 inch Exmarx walkbehinds and mow it 1/2 (lowest we can go). After that I will attach the seeder to my 4 wheeler and over seed with bermuda. it should push green in a couple of weeks. By next year it should be a plush carpet of green grass. Good thing about bermuda you can keep it 1/2 inch short with out killing it. This should make the runway perfect. Well the only other thing that would make it perfect would be to black top the thing but that is big bucks
