RE: Flaps setup
If the flaps are deflected upwards, the wing tips will usually stall first. The plane will drop a wing if you fly too slowly. Flaps down will increase stability when flying slowly. If you need better brakes and your radio can handle it, you could drop the ailerons slightly together with the flaps, or raise the ailerons if you don't need the extra lift.
