E-Maxx breakable parts?
Tsk Tsk..
The most common parts you will break on a new emaxx will be the rear slider shafts, if you are doing alot of high traction running and doing wheelies you will twist the rear drive shafts!! You will also go through some turnbuckles as well if you run on carpet!!
