Originally posted by adeoliver
Tsk Tsk..
The most common parts you will break on a new emaxx will be the rear slider shafts, if you are doing alot of high traction running and doing wheelies you will twist the rear drive shafts!! You will also go through some turnbuckles as well if you run on carpet!!
actually i only broke front ones for some reason on my emaxx
lol and get shock caps... loooooooooots of shock caps.... if you do as much jumping as i did ur going to blow those out no problem. its the infamous "traxxas pop"
