RCU Forums - View Single Post - Thrust Pipe Gap Question
Old 03-31-2011 | 07:12 PM
fw190pilot
Default RE: Thrust Pipe Gap Question
The way I understand it is the gap helps to draw cooling air through the pipe. Too close and that doesn't happen and will have problems with heat and reduced thrust. Too far and exhaust escapes into the fuse (not pretty). Optimum distance will depend somewhat on the install.
