RE: F3A MONOLOG 2X2 F3A METER
Jarvis,
I am interested in Monolog. Just waiting for your next few more postings of flight report.
Meanwhile, I have a few questions to ask.
Does the plane pitch to belly with rudder input during the level flight?
Are the incidence preset from factory? manual shows gluing the incidence pins & ply-rings.
Based on the manual, it seems that the plane was built for glow setup as it shows a template on cutting the air exit on the back of the fuselage.
Control horn slots are not pre-cut from the factory. I doubt if I can use dremel with rotozip bit to cut it out. How did you cut the slot?
What is your final RTF weight? Did you add weight to right wing panel?
Let us know.
