RE: Low turnouts for District 7 contests
I'm curious what you're hearing as I have the same setup as you basically and have had no problems. I DID have the loose stab tube issue, but I fixed it with some modification to the tube itself. I may end up gluing in the tube once I'm done trimming the airplane.
I wonder if the noise you're hearing is the result of a motor timing issue with the controller?
