RCU Forums - View Single Post - NitroModel Low-Wing Trainer 60 - 71"
Old 04-02-2011 | 07:03 AM
pjwright's Avatar
pjwright
Default RE: NitroModel Low-Wing Trainer 60 - 71
Pejuve - I snapped one main leg while I owned this plane, and it was a simple matter of bending new music wire to match the original. The bigger issue is the LG support structure within the wing. As built, mine had soft plywood bearers attached with insufficient glue. I removed these, and replaced with birch dowel drilled end-on to capture the torsion wire - braced in place with birch plywood epoxied to the spars. Then recovered the lower wing (2 rib bays) with Royal Blue Monokote (as I recall) for best color match.
Sorry - took no pictures of the surgery...
PJ
