RCU Forums - View Single Post - Aileron Flutter in a Ultimate, help needed
Old 04-02-2011 | 02:05 PM
jester_s1
Moderator
Default RE: Aileron Flutter in a Ultimate, help needed
If the crash was the moment when this started, I would look for a bad hinge or a crack in the wing or aileron. Flutter that didn't remove the aileron from the plane shouldn't have torn up your hinge seals, but if a hinge has failed allowing the aileron to pull away from the trailing edge of the wing that would explain it.
