RCU Forums - View Single Post - MINI C CAVITATION PROBLEM
Old 04-02-2011 | 04:40 PM
fgroza
Default RE: MINI C CAVITATION PROBLEM
You may need to run the smallest bronze prop Octura makes!!Hi rpm usually needs small props whereas low kv can turn larger props..
Im running a Mega 3 turn- 3000kv- with a TP 1350 3 cell turning a small 2 blade Octura prop, around 1" dia. I forget exactly maybe a 1427.
Frank
