RCU Forums - View Single Post - Quick, easy, and cheap LED control
Old 04-02-2011 | 06:44 PM
Argess's Avatar
Argess
Default RE: Quick, easy, and cheap LED control
Hey, and if you mount a switch with the throttle/brake servo and select ABS (for radios that have it), with a little adjustment, you could have flashing brake lights when you apply the brakes.
Or maybe it's so fast, the lights would apear merely ON, and a bit dim..........oh well, just a thought.
Regardless, a cool set-up you did. Thank-you for sharing.
