RCU Forums - View Single Post - Aerobatic bi-plane wing & Stabilizer incidence / Precedent Bifly
Old 04-03-2011 | 04:22 AM
charlie111's Avatar
charlie111
Default RE: Aerobatic bi-plane wing & Stabilizer incidence / Precedent Bifly
I can tell you If you suspend the plane from the wingtips at the high point of the curve on the top off the wing you'll be close.If the wings are not directly on top of each other meaning one is forward from the other you may heve to do it from both points and it should be between the two
