RE: TMMY Scale Composites 35% scale Cessna
Hi Ozflyboy
and 'all happened on the ground!!
and 'skid and the front end is given
when the turbine develops all its power on the right and pulls very much grass drifter
looked like a rally car!!
I hope you understood why I can not speak English and I'm using google translate
Still I must reinforce the tail on the coupling flanges of wood where there are 4 screws
and heavy tail and flanges are just stuck there are no reinforcements.
not use the glue that tommy and 'two-component resin
Tommy uses a glue that comes off easily and 'that yellow cream
model and the 'glue that heavy and insufficient.
you do not want to frighten everyone, but I advise you to reinforce the tail area of the 4 screws (the flanges of wood in black)
even the inside wing Renting
no later than tomorrow, I send you photos of the details and that 'best reinforce
tommy unfortunately reinforced in these areas very little.
in these areas and instead 'reinforce important!
I did not think that a rejected take-off would cause damage to these areas are broken most 'important.
but I wonder? and if all this was happening in the air? would be a tragedy!
