RCU Forums - View Single Post - Advantage of 2 receivers?
Old 08-11-2003 | 07:42 PM
LancelowDowell
Default Advantage of 2 receivers?
The reason for gold plating is because gold has a very low electrical resistance. It's been a while since I've dealt with electronics, but not many things have a lower resistance then gold, and most of those cost alot more. Since conectors are a usual spot for higher resistance, you can gold plate them to try to help reduce it. Does it make a difference? Maybe. Will you notice it? probably not.
