RCU Forums - View Single Post - Advantage of 2 receivers?
Old 08-12-2003 | 11:38 AM
Forgues Research's Avatar
Forgues Research
My Feedback: (7)
Default Advantage of 2 receivers?
Originally posted by hkyplr18
I understand redundency to the fullest,I fly a jet that has tons of redundant systems for a living(not as many as a 757) .There has to be a better reason why people are using 2 recievers. What fails in a reciever? Its solid state... overvoltage could do it maybe? No.. nothing can cause overvoltage in these things. The main reason rc airplanes crash because of a radio problem is 1)Radio interference 2)some nit-wit turns his radio on. Two problems that 2 recievers wont make a bit of difference in. I have heard of everything in an RC aircraft fail, except a receiver. I have been told its because the larger airplanes 35% and up need to split the load of all 15+ servos between 2 receivers because 1 reciever cant handle it all.(does that sound right) it does to me... You can have 10 receivers in your airplane, and still stick your plane in the dirt because your one and only transmitter just decided to bite the dust.I am ranting and raving, sorry, just looking for an excuse not to buy another reciever. It's cheap insurance I guess......well not really too cheap.....
I agree that one receiver is all one needs. A lot of people are going to 2 receivers because of the expense of the airplane, yet, with the smaller, cheaper, trainers which were most likely assembled by beginers, chances are that these receivers were not installed properly and and still never failed, so the receiver in the large airplane doesn't know the airplane is big, so it won't fail either.
The other point, with two receivers, having one side of the airplane on one receiver and the other side being on the other receiver, then that is a disaster waiting to happen with a false sense of security.
If one insists on going to two receivers, then at least go with a system that should a receiver fail for any reason such as batteries, switches and such, you would continue operating on all controls. dual redundency
I personally favor a single receiver but not connecting any servos directly to it, with having a seperate power supply for the servos.
power supply
